Add arrow head to line segment to show direction of line
  • Jan 26, 2021 6:11 PM UTC
  • 146 views
gcarmich
Participant
I've created straight line segments using the VertexCreator (x2) and Rotator. I need to add an arrowhead on each line segment to show the direction (from vertex 1 to vertex 2). I tried to copy the approach listed here:
https://community.safe.com/s/question/0D54Q000080hg35/convert-line-to-an-arraw?t=1611682329612
but I'm not getting an arrowhead as a result. There is mention of 2DPointAdder but I don't see 2DPointAdder as a Transform. Also I don;t understand the Line and ArrowHead portion of the solution on the link.
My approach so far is:
What am I missing?
gcarmich
Participant
  • Participant
  • Jan 26, 2021 6:12 PM UTC
My approach so far:
Forum|alt.badge.img+54
  • Jan 26, 2021 8:09 PM UTC
I snip the end of the line, clone it and then rotate one segment one way, and one the other way
Edit: i see that is your approach, what sort of length are your lines, the snipping values you have don't look like they'll be the correct ones unless all your lines are exactly 100 long?
CaptureCapture
gcarmich
Participant
  • Participant
  • Jan 26, 2021 8:42 PM UTC
CaptureCapture
Thanks - I see my mistake. I Snipped based on distance instead of percentage. It's working now.
