Add a dot to the last three numbers
  • Nov 19, 2021 7:46 AM UTC
  • 8 replies
  • 120 views
arash_hokm
Forum|alt.badge.img+8
Hi FME Community,
I have a column with number. I want to add a dot to the last three numbers.
the pictures show what I expect as a result:what I expect as a resultwhat I have:
what I haveThanks in advance :)
Best answer by nielsgerrits
@nielsgerrits​ I have a problem with process execution. I actually have this value:
FME3 then I deleted points by using StringReplacer (up to here works very well)
FME5and divided my value by 1000 by using AttributeCreator. Nevertheless, I get a warning and my column is not filled with anything. (I also converted my value to int64 but it didn't work either) (all lines also have values).
 as a warning I get:
AttributeCreator_2: Failed to evaluate expression '@real64(<null>/1000)'. Result is set to null
FME4
Then your formula is wrong. It needs to be
@Evaluate(@Value(col11)/1000)
nielsgerrits
Forum|alt.badge.img+67
Devide it by 1000.
AttributeCreator, AttributeA = @Evaluate(@Value(AttributeA)/1000)
arash_hokm
  • Nov 19, 2021 8:47 AM UTC
oh that was very simple what I was thinking.
thanks alot @nielsgerrits​
arash_hokm
  • Nov 19, 2021 9:49 AM UTC
as a warning I get:
FME4
nielsgerrits
as a warning I get:
FME4
This means that the AttributeCreator finds a row with a null value, and null/1000 is invalid. Put a Tester between the StringReplacer and AttributeCreator_2, test Attribute has a value.
arash_hokm
  • Nov 19, 2021 10:47 AM UTC
as a warning I get:
FME4
@nielsgerrits​ I have already filtered all null, missing and empty attributes beforehand.
I watch my values ​​after StringReplacer and after AttributeCreator_2 by Inspector
FME10Inspector _3:
FME9inspector_2:FME7inspector_3:
FME8
Forum|alt.badge.img+54
  • Nov 19, 2021 10:50 AM UTC
as a warning I get:
FME4
Is it possible that there are records that just have .... entry so are not null at the stage of your tester but are null after the string replacer?
nielsgerrits
  • Nov 19, 2021 10:52 AM UTC
 as a warning I get:
FME4
arash_hokm
  • Nov 19, 2021 10:57 AM UTC
as a warning I get:
FME4
@nielsgerrits​ perfect. Thank you very much :)
