A ridiculous problem
  • February 9, 2014
  • 63 views
This seems to me to be quite a ridiculous problem, but I can't find a way to solve it. I have an attribute that comes from an Apache 2.2.25 API connected through a HTTPFetcher that I need to split into a number of new attributes. This is an exapmle of the attribute with the kind of data it contains (alsways numbers of vaying lenght separated by "/"):
Attribute X
12345
12345/123456
12345/123456/12345
123456/12345
What I need is this result:
Attribute X                           AttributeNew1      AttributeNew2      AttributeNew3
12345                                 12345                    <blank>                 <blank>
12345/123456                  12345                    123456                  <blank>
12345/123456/12345      12345                    123456                 12345
123456/12345                   123456                  12345                   <blank>
What I get now is this:
12345                                 <blank>                 <blank>                 <blank>
12345/123456                  123456                  <blank>                 <blank>
12345/123456/12345      123456                 12345                    <blank>
123456/12345                   12345                   <blank>                 <blank>
In other words, the splitter does not transfer the first value to a new attribute. I've been trying a lot of different approaches without any luck. Ant ideas on what to do?
Thank you!
Chris
fmelizard
Forum|alt.badge.img+22
  • February 9, 2014
the results of the splitter are stored in a list, you can copy the list element values into new attribute values or explode it to new features.
  • February 10, 2014
Itay is right. Try splitting the attribute value at slash (AttributeSplitter), and renaming individual list elements (AttributeRenamer).
_list{0} --> AttributeNew1
_list{1} --> AttributeNew2
_list{2} --> AttributeNew3
Takashi
  • February 10, 2014
Of course! There can be up to 50 numbers in that attribute, so my list gets pretty long. Now I see that i startet the renaming at _list{1} instead of _list{0}. I knew this was a ridiculous problem. :) Thank you both for the feedback!
Chris
