A problem of flipping CityGML Appearance
  • Sep 13, 2023 1:08 AM UTC
  • 0 replies
  • 59 views
Hi guys, I am working on a 3d building model conversion to cityGML
I have several openings and I tried flipping them with their original geometries
​화면I set the gml_geometry_reversed attribute and used GeometryPropertySetter(gml_geometry_reversed, xlink_href) to make the orientableSurface as follows
화면 캡처 2023-09-13 095221the orientable surface was successfully generated
화면 캡처 2023-09-13 094901but when I open the file with the inspector its appearance was flipped in wrong way
화면 캡처 2023-09-13 095859the windows and doors are supposed to be like this
화면 캡처 2023-09-13 100527
I GUESS the appearance part in the document must be written incorrectly
(specifically, <app:inFront>fasle</app:inFront> part)
this is true part
화면 캡처 2023-09-13 095038​and this one is false part화면 캡처 2023-09-13 095056the order of the coordinates is the same for both parts...I am not sure this has something to do with the flipping issue
I have no idea how to edit the transformers and fix this problem please help me solving it...!!😂
