3d PDF zoom issue
  • February 27, 2013
  • 52 views
I have created a 3d PDF and when i zoom in the background feature obscures the feature. You can see the issue if you look at the Lanai and Molokai in a 3D PDF.pdf located at http://fmepedia.safe.com/servlet/fileField?retURL=%2Farticles%2FSamples_and_Demos%2F3D-Textured-Examples&entityId=ka430000000VbxHAAS&field=Documentation_Link4__Body__s
I'm using Acrobat Reader X.
Additionally i have TerraGo toolbar installed and the Measure Length command is not enables on either the PDF i created or the Lanai PDF.
sigtill
Forum|alt.badge.img+25
  • February 28, 2013
Hi Tim!
Do you have a screenshot of your issue?
  • February 28, 2013
My colleague pointed out my novice mistake with the zooming - i needed to select 'Use Orthographic Projection".  However my Terrago command issues still exists.
  • February 28, 2013
Try explicitely setting the coordinate system on the Writer, if you haven't done so already.
David
  • July 5, 2013
what is your command line you are using. it may causes the background feature obscures. so we need to pay attention to when we are zooming pdf vb.net.
