3D Data validation by using FME
  • January 5, 2013
  • 68 views
Hi All,
We are in the process of procurment of FME software for validating 3D data, (validating tools for finding errors like gaps, flipped surfaces, box-in-box, in correct geometry etc.,).Could you please suggest which edition of FME will fulfill our requirements.
fmelizard
Forum|alt.badge.img+22
  • January 5, 2013
Since the validation will take place using the transformers, a professional edition (and above) would be my choice.
For more info about FME editions, see
http://www.safe.com/fme/fme-technology/fme-desktop/fme-editions/
I would also consider purchasing the MFR transformers set.
http://docs.safe.com/fme/html/FME_Transformers/FMETransformers.htm#transformers/mrf2dcleaner.htm
Hope this helps,
Itay
sigtill
Forum|alt.badge.img+25
  • January 5, 2013
You should also go for the 2013 version of FME (released soon) as it contains many improvements related to 3D-data. I agree with Itay that a fME Professional license would be best suited for you - unless you need to take advantage of some specific database environments.
To see which file-formats are supported on which FME - versions you can look it up here: http://www.safe.com/fme/format-search/
