1st row as Column
Forum|alt.badge.img+5
Name attribute will come in columns and value come in rows
Is there any way to that
Output come like this
j.botterill
Forum|alt.badge.img+37
  • June 1, 2022
how are you reading the data in? If CSV or Excel in the reader, you can go to Parameters of the reader and for the sheet you're interested in.... change the Field Name row = 2
then down the bottom - change the "Attributes" Name to be timezone and CDTreaderparameters FieldNames rowOther tips:
Expose the reader format types and introduce TestFilters for processing certain row = 2 etc. Also utilising attributetransposer/exploder transformers
virtualcitymatt
Forum|alt.badge.img+35
You need to use the AttributeCreator and you can set the following settings
This will not 'expose' the attributes though for use or for the output schema so you need to follow it with an AttributeExposer
  • June 1, 2022
No i m using KMZ file
  • June 1, 2022
now its coming like this
j.botterill
  • June 2, 2022
perhaps you can run the workspace to the last transformer
then go File > Save as template and tick to include the feature cache
Reply to this and attach the .fmwt
virtualcitymatt
Oh yeah, right - you need to run it through an Aggregator to squish then into one feature
