1. How do I export, to an excel template, data from a Survey123 form that has related tables? 2. Rather than overwriting the excel file, how can a create a new excel file from the Parent record, while integrating in the Survey123 related tables
  • Apr 12, 2023 9:13 PM UTC
  • 358 views
I have a Survey123 form, that needs to be exported to a specific excel template file. The Survey123 form has 1 layer (parent record), and two related tables associated with that single record. The final format for the excel template would need to be 1 file per record, with two sheets (from the two related tables). Prior to exporting out to the template files, I would need to filter the data down by a site name
For instance, a site (that I have filtered down to) may have 4 records taken on it, so I would need to create 4 separate excel files, based on a Plot ID field. Each on of these excel files would then have 2 sheets based on the related tables of the record.
Open to suggestions and comments. Thank you!
Best answer by engelm1324
What I ended up doing was having a series of attribute managers that ultimately went to 1 excel document. I was able to use the fanout method based on a certain attribute to create the additional excel spreadsheets. Here is my solution to my question. This may need some clean up, but for now it is getting me what I need.
Solution
wisegis
Forum|alt.badge.img+17
  • Apr 14, 2023 3:22 AM UTC
I just looked at my Survey123 export I created a while back, and it is bananas. To keep this answer simple, the trick to what you are trying to do is all at the Writer. I created an attribute during the process and called Excel_Tab_Name. They made it something really hard and I did a calculated field in the AttributeManager for that.
In the General section at the top of your writer, you will assign the field for the tabs. I had to create a row_id to ensure all the Survey123 data went into the correct place for each spreadsheet. The writer's field was the actual columns in each tab (A, B,& D).
Hope that helped.
  • Apr 14, 2023 3:41 PM UTC
Thanks! I will give this a shot.
  • Apr 17, 2023 6:51 PM UTC
Solution
