Points on Area Overlay: count points on multipart features
  • September 14, 2017
  • 14 views
pinkopo
Forum|alt.badge.img+5
Hi guys,
I am trying to use point overlay to get a point count over polygons, but everytime the Point Area Overlay transformer seems explode the multi-parts polygons. Is there anyway i can avoid this?
Thanks!
Best answer by gio
@sangli
You can also use a spatialrelator for this. The geometry will not be exploded.
If you have points as supplier (test = contains), you can us a listelementcounter to count the elements in the list.
If you have points as requestor (test = Within), you can use a Statistics calculator grouped by the area id to count the points within.
Hi @sangli, currently there is no way to prevent exploding (de-aggregating) input multi-part areas, unfortunately. A possible workaround is: use the Aggregator to aggregate the output areas.
  • Group By: <set unique ID attribute of original areas>
  • Attributes to Sum: <set the Overlap Count Attribute specified in the PoinOnAreaOverlayer>
If the original area features don't have unique ID attribute, you can use a Counter to add sequential number to the features as temporary ID before inputting them to the PointOnAreaOverlayer.
gio
Forum|alt.badge.img+15
@sangli
pinkopo
  • September 15, 2017
Thank you Takashi that's a great idea! :)
