FMEserver with active directory
raphael
Participant
Hello,
I've connected my FMEserver with one active directory.
I can connect to my FMEserver and I can navigate between the differents menus except the security menu where i have an error :
 javax.servlet.ServletExceptionjavax.servlet.ServletExceptionCOM.safe.fmeserver.api.FMEServerExceptionCould not read FME Server response messageConnection may have been lost.Une connexion existante a dû être fermée par lhôte distant 	COM.safe.web.servlet.PageServer2.doGet(PageServer2.java:107) 	javax.servlet.http.HttpServlet.service(HttpServlet.java:621) 	javax.servlet.http.HttpServlet.service(HttpServlet.java:722) 	COM.safe.fmeserver.webui.sitemap.SiteMapFilter.doFilter(SiteMapFilter.java:40) 	COM.safe.web.servlet.CharsetEncodingFilter.doFilter(CharsetEncodingFilter.java:538) 	COM.safe.webservices.security.FMEServerAuthFilter.doFilter(FMEServerAuthFilter.java:164) Do you have an idea ? Thanks
Be the first to reply!
