Hi All,
I have a workbench that reads a feature service from ArcGIS Online exposing the actual attachment attribute associated with each feature and then extracting the photos attached to it.
I'm using RasteReplacer to convert the BLOB data to a JPEG and then writing it with a JPEG writer (with the option to save the EXIF data ticked).
However, it doesn't look like the EXIF metadata is writing to the JPEG.
I'm sure that the EXIF metadata does exist as I have an existing Python script that uses Arcpy to extract the JPEGs with EXIF out from a file geodatabase. But when I do it through the ArcGIS Online feature service reader, it doesn't seem to be retaining this information .
Any help on this would be much appreciated.
