Best Postgis version for Fme 2013 sp1
whit
Forum|alt.badge.img+3
Does anyone know the latest, most stable postgre postgis version tested with fme server 2013 sp1 for windows 32 bit?
Or even just a recommendation?
I suspect it is postgre 9.1 with postgre 2.0.x on stackbulder
but i wanted to confirm as we are configuring a new dev server.
Thanks, Reed
Forum|alt.badge.img+4
  • April 16, 2013
If you're talking about the database for FME Server, are you aware that FME Server 2013 ships with prepackaged prerequisites nowadays? PostGres auto-installs with FME Server if you run a Express Install.
As for a recommendation, we're using PostgreSQL 9.1 64-bit with PostGIS 2 and we've had no problems with it. Just configured ours successfully with http://fmepedia.safe.com/articles/Samples_and_Demos/Simple-Tracker-demo-for-FME-Mobile-Apps
whit
  • April 23, 2013
Thanks Kathy.
I did not realize that PostGIS 2.0 was pre-installed with FME Server 2013  (I thought that was a 2014 thing).   Thanks for that.
FME 2013 sp1 is working very well with postgis 2.0 BTY.
Regards, Reed
