In FME2013 I am having a problem with BoundingBoxReplacer crashing when set to Oriented Bounding Box. I am feeding it output from the Aggregator transformer.
Has anyone else had this issue? It worked fine in FME2011.
Does it crash with the usual Windows "fme.exe has experienced an error and has had to close", or is it an error message in the log?
If it's a crash then for sure you should send it to your support contact and have them investigate.
You might be able to run it through the GeometryValidator (especially the tests for "Basic Geometry Integrity") and resolve the issue, but a crash is a crash and we should still like to try fix it.
Sorry, I should have been more specific. It was failing at the BoundingBoxReplacer with an error:
"BoundingBoxReplacer: Cannot handle geometric aggregates which contain things other than lines, points, polygons or donut polygons"
This morning I installed Service Pack 1 and it seems to have fixed the problem. I'm not sure what changed between the initial release and SP1 to fix it though.
We use 3 different kinds of cookies. You can choose which cookies you want to accept. We need basic cookies to make this site work, therefore these are the minimum you can select. Learn more about our cookies.
