How to clamp altitudes down on WGS84?
  • January 12, 2017
  • 9 views
Hi everyone!
I have several building models in SWEREF99 which is the coordinate system used in Sweden. I successfully converted coordinates to WGS84-geocentric using csMapReprojector but buildings are now several meters above the surface of WGS84. How can I clamp those buildings to WGS84?
P.S: The height reference used in Sweden is called RH2000.
Thanks in advance!
daveatsafe
Forum|alt.badge.img+19
  • February 1, 2017
