how to save an attribute to an oracle date type column?
arthy
Forum|alt.badge.img+8
I have an attribute (timeattribute) that I would like to save to an oracle table
  timeattribute = '2017-06-30 18:39:05'
Within a sqlexecuor, I'm doing something like:
INSERT INTO TEST_T
    OBJECTID,
    TIMEATTRIBUTE
  VALUES
    @Value(OBJECTID),
   '@Value(TIMEATTRIBUTE)'
and it failed. How can I make it work?
FYI, the query
INSERT INTO TEST_T
    OBJECTID,
    TIMEATTRIBUTE
  VALUES
    @Value(OBJECTID),
   sysdate
worked perfectly within the sqlexecutor.
Thanks
Best answer by david_r
This is more of an Oracle question, you'll have to use the to_date() function. Example:
INSERT INTO TEST_T
    OBJECTID,
    TIMEATTRIBUTE
  VALUES
    @Value(OBJECTID),
   to_date('@Value(TIMEATTRIBUTE)''YYYY-MM-DD HH24:MI:SS')
Forum|alt.badge.img+31
  • July 4, 2017
You need to use the to_date function to insert into oracle, e.g.
  • July 4, 2017
INSERT INTO TEST_T
    OBJECTID,
    TIMEATTRIBUTE
  VALUES
    @Value(OBJECTID),
  • July 4, 2017
Just another thing, you should be careful about manually inserting OBJECTID values unless you've queried the relevant SDE function for the next value. The issue is that the OBJECTID column is tied to an Oracle sequence and if you insert your own values without simultaneously updating the sequence you risk primary key collisions down the line.
From the ESRI FAQ: http://support.esri.com/en/technical-article/000008996
More technical info here: http://desktop.arcgis.com/en/arcmap/10.3/manage-data/using-sql-with-gdbs/next-rowid.htm
arthy
  • July 4, 2017
INSERT INTO TEST_T
    OBJECTID,
    TIMEATTRIBUTE
  VALUES
    @Value(OBJECTID),
@david_r,
Thanks
