Blend 3D points with an ortho photo
Dear Community,
I want to blend 3D points with an ortho image, to get an aerial image with a DEM.
My aim is it to get a 3D PDF or a geo-tif, where I can see all hills, streets and other uprisings but with an ortho photo on it. Now I want to know how to blend these datas with each other and what transformers I`ll require to do this?
Can you please help me to fix the problem?
Kind regards from Würzburg (Germany)
  • May 12, 2015
there is a short video here that shows how it's done:
https://www.youtube.com/watch?v=edZeJLWDqiQ
David
gio
Forum|alt.badge.img+15
  • May 12, 2015
clip your photo with the bounginbox of the the DEM and use a AppearanceSetter.
Thank`s for your answers. But can you please send me a screenshot of your Workbench when you solved the problem?
gio
  • May 12, 2015
I have one here wich like puts a bunch of stuff together...vector, 3dBuilding (more like blocks..;) a raster and a aerial selection.
Its an old script btw, unchanged since fme2013 i guesslike.
and its output
gio
  • May 12, 2015
btw. You can also directly project rasters on points cloud.
You can use PointCloudOnRasterComponentSetter to do that.
Can look nice too..
The white thing is Leiden trainstation..
