data download with excel template
owen
Hello,
I have a workspace that updates an existing excel template.
When publishing it to a data download service, it writes the excel file, but doesnt use the file specified in the writer.
I know this is because the data download writes to a temp location, not the writer output folder - is there anyway to force it to use a template?
Owen
nrich
Forum|alt.badge.img+5
  • May 16, 2013
hi owen,
see http://fmepedia.safe.com/articles/How_To/Data-Download-Service-Writing-to-a-template-ESRI-File-Based-Geodatabase
this is working for me and personal geodatabases.
set the file_copy writer to D:\\ and the excel writer to d:\\myexcelfile.xls, after you have registered the workbench with the download service D:\\ should be replaced with the temp download path on both writers and hey presto your template is in the download directory for your writer to connect too.
regards,
Nick
owen
  • May 17, 2013
A-ha! I couldnt find a way, so thats really useful. Now wheres that temp folder....
