Getting Null value in feature 'Z'
How we will identify the "Null" value in Particular feature  "Z" coordinate in shape file.
Attached screen below
gio
Forum|alt.badge.img+15
  • January 7, 2015
Using Arcmap (Esri site has lots of HowTos) or Using fme?
  • January 7, 2015
you can use the DimensionExtractor in FME to test if a feature is either 2D or 3D.
David
