Convert dbase tot cad
  • February 6, 2013
  • 16 views
I have a .dbf table with X, y and Z coordinates. I need to convert this to a dxf file with z-coordinate. How do I do that?
I'm quite a newbee in FME, but that's not surprising I think.
Joost
Forum|alt.badge.img+50
You can use a 3DPointReplacer to create 3D points out of your DBF records, then write that to DXF.
davideagle
Forum|alt.badge.img+21
  • February 6, 2013
Or a 3DForcer with the attribute set to Z might be useful to know about too...
  • February 7, 2013
Thanks!
