Sometimes the log files confuse what version of database I am using. Does ORACLE8I mean FME is trying to use Oracle version 8i?
  • March 22, 2017
  • 10 views
fmelizard
Forum|alt.badge.img+17
2017-03-15 19:46:42| 131.8| 0.0|INFORM|ORACLE Reader: Using Oracle Reader to read tables from database `', server type `ORACLE8i', server name `bebop', user name `importantuser', password `***'
Best answer by fmelizard
No. ORACLE8I is a term we chose in the past and FME continues to use that term to refer to the Oracle format in general. The actual Oracle software installed determines the version of Oracle in use.
For example:
2017-03-15 19:46:45| 132.2| 0.0|INFORM|Oracle database version is '10.2.0'
fmelizard
  • March 22, 2017
For example:
