Error Handling: Translation was SUCCESSFUL...are you sure?
  • Oct 16, 2026 4:30 PM UTC
  • 0 replies
  • 66 views
shirleychan
Forum|alt.badge.img+9
Happy Friday, FME community! In this week's TGIF, we're tackling a tip every FME user eventually needs: what to do when things go wrong.
"Translation was successful" only means the run finished without errors. Sam will walk through a Workbench, then look at how FME Flow Automations handles success and failure routing. Proactive alerts can be set up to alert you what happens when nobody is watching.
Check out the video walkthrough here - https://youtu.be/T9q7TKsqVDI
Enjoy the weekend! Your workspaces will be right where you left them!
