For quite some HTTPcallers and different connections we switched the authentication method authentication from Basic (with username and password) to Web connections. When using Basic authentication, nu warnings or errors appear. But to keep the workspaces maintainable and safe, we decided to switch to Web connections.
But after this change, the following warnings started appearing in FME Flow:
HTTPCaller (HTTPFactory): Certificate verification will be disabled because verification is turned off for the '…' web connection
The web connections have the checkbox for ‘Verify HTTPS certificates’ enabled (in Form).
It happens for FME Flow web connections as well as HTTP web connection types.
How can we avoid these warnings?
We're using FME Form 2025.2.4 and FME Flow 2025.2.4
