Random "Basic realm=FME Server Authentication" login popup on Workspace App load after upgrade to FME Flow 2026.2 (SAML + IIS reverse proxy)
  • Jul 28, 2026 10:09 AM UTC
  • 83 views
felix.pekarek
Since upgrading from FME Flow 2025.2 to 2026.2, we are seeing a recurring authentication problem with our Workspace Apps. When a user opens or reloads an app, a native browser Basic Authentication popup appears intermittently, roughly every second or third load. Because we use SAML, our users have no local username or password to enter and are forced to click Cancel every time. After cancelling, the app works normally, but the repeated prompt is disruptive for end users.
Our setup: FME Flow runs under HTTP behind an IIS reverse proxy (Application Request Routing) that enforces HTTPS. Authentication is handled through SAML with Azure AD as the identity provider using SP initiated login. On IIS, only Anonymous Authentication is enabled while Windows and Basic Authentication are disabled, and the SAML base URL is correctly configured.
Using the browser developer tools, I captured the exact request that returns the 401. It is a GET to the Data Upload Service that the app fires in the background to browse and list uploaded files (/fmedataupload//.fmw?opt_pathlevel=-1&opt_fullpath=true&opt_serverapp=). The response comes back with status 401 Unauthorized and the header Www-Authenticate: Basic realm="FME Server Authentication".
Interestingly, the issue only seems to occur in Workspace Apps that allow users to upload files. I can reproduce it within other apps that allow uploading some data. Workspace Apps without upload parameters do not trigger the authentication dialog.
This is the authentification windows that is appearing repeatedly:
Has anyone else experienced this behavior after upgrading to FME Flow 2026.2, or is there a known workaround?
zoe.forbes
Forum|alt.badge.img+10
  • Jul 29, 2026 5:24 PM UTC
Hi ​@felix.pekarek,
We’re aware of this bug and have filed it internally as FMEFLOW-28833, but are still looking on a workaround.
Can you confirm if the affected apps are Authenticated? We’ve only seen this occur for authenticated Workspace Apps with a file User Parameter.
I’m going to add an entry to our Known Issues table, it should appear over the next few days.
Thanks for your post!
felix.pekarek
  • Jul 30, 2026 5:32 AM UTC
Yes I can confirm that it’s an authenticated app. I can also confirm that it doesn’t happen with unauthenticated apps, because with those I can’t reproduce the error.
Thanks for the help! 😁
