I got an error in starting FME workbench 2022.2.5 after windows 11 update
  • May 12, 2023 9:57 AM UTC
  • 321 views
FMEworkbench wil not start after an update from Windows 11 last week.
It starts with the start-screen but after "Initializing main window" stops the startup
I'm working with version 2022.2.5 build 22795
I got the details in the following errorlog (in dutch):
Logboeknaam:  Application
Bron:         Application Error
Datum:        12-5-2023 10:19:51
Gebeurtenis-id:1000
Taakcategorie: Toepassingscrash-gebeurtenissen
Niveau:       Fout
Trefwoorden:
Gebruiker:
Computer:
Beschrijving:
Naam van toepassing met fout: fmeworkbench.exe, versie: 2022.7.45.22795, tijdstempel: 0x6424fcdc
Naam van module met fout: Qt6WebEngineCore_fme.dll, versie: 6.2.4.0, tijdstempel: 0x625ef5dc
Uitzonderingscode: 0x80000003
Foutmarge: 0x0000000002645d96
Id van proces met fout: 0x0x4388
Starttijd van toepassing met fout: 0x0x1D984AA82E9B0AB
Pad naar toepassing met fout: C:\\Program Files\\FME\\fmeworkbench.exe
Pad naar module met fout: C:\\Program Files\\FME\\Qt6WebEngineCore_fme.dll
Rapport-id: feefc3f6-3f26-4480-8894-f3096dd087be
Schermafbeelding 2023-05-12 115305
http://schemas.microsoft.com/win/2004/08/events/event
Best answer by david_r
I've been running many different versions of FME on Windows 11 (up to date as of today) without any such problems. My first suggestion would be to try reinstalling FME.
  • May 12, 2023 10:19 AM UTC
  • May 12, 2023 11:30 AM UTC
Thanks David_r, a repair-installation from the last installed version from FME worked
