After upgrading from FME 2025.0.1 to 2026.3, via HTTPCaller SSO returns 401 against on prem Power BI Report Server. It worked before the upgrade.
some tests:
| Client | Method | Result |
| PowerShell Invoke-WebRequest | Default Windows credentials | 200 |
| curl 8.13.0 | --ntlm -u : | 200 |
| curl 8.13.0 | --negotiate -u : | 401 |
| FME HTTPCaller | NTLM, typed DOMAIN\user and password | 200 |
| FME HTTPCaller | Single Sign On | 401 |
Single Sign On behaves like curl's Negotiate result. We suspect it doesn't fall back to NTLM, but we can't confirm that.
The server, the account's permissions and NTLM authentication all work, since PowerShell, curl and FME with typed NTLM credentiials all succeed, so the failure appears specific to FME's Single Sign On method, which may not be falling back to NTLM when the server offers NTLM only.
Now some questions:
- How does HTTPCaller Single Sign On choose its authentication scheme, and is this documented? I found no documentation on how SSO works in FME, so I need some guidance.
- Could I be missing some config to get this to work that was introduced into fme 2026.3? (it also doesn't work on fme flow though)
- Is Single Sign On expected to work against a server that offers NTLM only?
Thanks
