FMECloud and ADFS
sigtill
Forum|alt.badge.img+24
Can you connect to ADFS (Active Directory Federation Services (ADFS) is a(SSO) solution created by Microsoft ) and handle login on FMECloud through this? Similar to connecting to AD on FME Server
Best answer by stewartatsafe
It is similar to that other request. The short answer is that, no, we cannot do this. We are however just about to migrate the FME Cloud login over to use Auth0 (same as Knowledge and Hub). This migration does open up the possibility to enable such workflows. Not on the roadmap at the moment though. I would file an idea.
sigtill
  • October 14, 2019
Acoording to this https://knowledge.safe.com/content/idea/98769/okta-single-sign-on-sso.html @stewart.harper isn`t a rookie on FMECloud I hear :)
stewartatsafe
Forum|alt.badge.img+5
  • October 15, 2019
