Does restore create new token?
  • Nov 30, 2017 1:41 PM UTC
  • 49 views
zzupljanin
Forum|alt.badge.img+5
I started restore in FME Server UI (Overwrite Existing Items was unchecked), then I immediatelly canceled it. After some time I realised my token is not same. Does restore create new token? Even if the process is canceled? What will happen with token if you run whole restore option?
Thank you
laurawatsafe
Forum|alt.badge.img+14
Hi @zzupljanin, The Restore shouldn't be creating a new token (and it especially shouldn't if the process was cancelled). Are you working with FME Server 2017? If so, had you generated a token with an expiry set for your user account? By default, the token will automatically re-generate every time you log in or every half hour if you haven't generated a new token for yourself with an expiry time set.
