CORS errors
  • Feb 13, 2025 5:42 PM UTC
  • 190 views
runneals
Forum|alt.badge.img+32
We're sending CORS headers, but not getting them back. How do we get them back?
hkingsbury
Forum|alt.badge.img+73
  • Feb 16, 2025 11:06 PM UTC
What’s the configuration of you CORS settings in the FME Flow UI?
todd_davis
Forum|alt.badge.img+23
  • Feb 17, 2025 1:06 AM UTC
As ​@hkingsbury mentioned, its all to do with your CORS settings and you need to add access-control-allow-origin . It is not in FME Flow's CORS settings by default and sometime it gets used, so is often something you need to add.
runneals
  • Feb 17, 2025 8:00 PM UTC
​@todd_davis ​@hkingsbury I’ve explicitly added them, at least I think I did? I also started with the default and started adding things to no luck.
