Connecting FME Flow to Azure AD
  • May 12, 2023 11:02 AM UTC
  • 112 views
sigtill
Forum|alt.badge.img+25
When connecting FME Flow to Azure (Configuring Azure Active Directory with FME Server (safe.com) - the app needs permission to:
  • Microsoft Graph > Application permissions > Group.Read.All, User.Read.All
  • Microsoft Graph > Delegated permissions > User.Read
However when using Azure AD and FME Form the following permissions are needed:
  •  Microsoft Graph User.Read Delegated
Is it possible to limit the FME Flow permissions to be the same as FME Desktop - or is there a reason you also need Group.Read.All and User.Read.All ?
ajengyarista
Forum|alt.badge.img+8
  • Nov 12, 2026 2:37 PM UTC
Hi, is there any update regarding this?
Our Azure administrator asked the same question of why Group.Read.All is needed as it gives a lot of rights such as reading all groups in Microsoft Entra ID and read members of all groups. They think it is not necessary.
shirleychan
Forum|alt.badge.img+9
Hi ​@ajengyarista,
Why FME Flow uses these permissions
The delegated User.Read permission covers sign-in. The application permissions (User.Read.All and Group.Read.All) are used by FME Flow’s own background Graph calls for directory features in the Web UI:
  • searching for and importing Entra ID users,
  • importing Entra ID groups as FME Flow roles,
  • keeping role membership in sync with group membership during each sync
Narrower alternative
In our testing, these lower-privilege replacements still allowed Entra ID sign-in plus user and group import:
  • User.ReadBasic.All in place of User.Read.All
  • GroupMember.Read.All in place of Group.Read.All
Please note that this set hasn’t been formally validated by our development team, so we’d recommend testing it in a non-production environment first.
One caveat for the admins: GroupMember.Read.All still applies across the whole tenant. Microsoft Graph application permissions can’t be limited to specific groups.
If access must be limited to specific users or groups
SAML-based Entra ID authentication may be a better fit. With SAML, users and groups are assigned to the Enterprise Application in Entra ID, and only assigned users can sign in to FME Flow. See Configuring FME Flow for Azure AD SAML Authentication in our docs. The trade-off is that SAML doesn’t use the Graph-based group import and sync.
I hope this helps!
