Azure AD SSO and embedded workspace app in ArcGIS Experience builder
  • Jan 14, 2025 11:42 AM UTC
  • 0 replies
  • 86 views
jeresv
Forum|alt.badge.img+10
Hi
We are about to configure Azure AD (Entra ID) Integration to authenticate users to our FME Flow.
There are some workspace applications (flow apps) that are embedded into an ArcGIS Portal Experience builder app. The authentication to the ArcGIS Portal is also done with Azure AD accounts.
The idea is, that the end user will open the ArcGIS Portal web application and access the FME Flow workspace application from that platform, rather than re-navigate to the Flow app.
If SSO is enabled, will the FME Workspace/Flow app application authenticate automatically without extra login to the workspace application, when it is accessed from the ArcGIS Portal Experience application, as it is embedded to the application? Current setup with basic user authentication and FME Flow user access control fully inside FME Flow naturally requires a log-in to the app OR requires the Flow app to be published without authentication, but we want to ensure security.
Does anyone have experience with this kind of setup? Should there be more configuration to it?
