Assign multiple roles to a user from Azure AD SAML claim
  • Jan 19, 2026 3:18 AM UTC
  • 6 replies
  • 177 views
anryan
Forum|alt.badge.img+8
Hi there,
In this article (Configure user attribute mapping with Azure AD SAML Provider – FME Support Center), a group claim can be setup to pass an AD group name which aligns to a role in FME Flow. As a group claim could be based on a search criterion and many AD groups could be returned which is a common method of Enterprise group membership in ArcGIS Enterprise software. I was wondering if this could be used to grant several roles to a user?
Looking at controlling access to repositories, who can view workspace and who can run a job, etc via AD group assignment.
Thanks
Best answer by zoe.forbes
Hi ​@anryan,
This isn’t currently possible but you’re welcome to submit an idea for this - Product Managers check Ideas to inform decision making. I’m also able to do this for you if you would prefer.
The best workaround I can think of would be exporting roles data outside of Azure, and creating a workspace which used the API to assign additional roles to Flow users after creation. The endpoint POST /accounts/{id}/roles could be used to do this.
Thanks,
Zoe
zoe.forbes
Forum|alt.badge.img+11
  • Feb 3, 2026 10:00 PM UTC
Hi ​@anryan,
Thanks,
Zoe
anryan
  • Feb 3, 2026 10:30 PM UTC
​@zoe.forbes thank you for the reply. I’ll be submitting an idea for this to utilise OOTB SSO/SAML capability.
I have a question regarding your workaround in using a workspace to assign the additional roles - You hadn’t mentioned what type of trigger could be used for this. I assume a schedule as I couldn’t find any documentation that FME Flow has internal webhooks (eg. trigger on user creation)?
At the moment, I’ll probably go for a schedule running every 30mins to check a defined list of AD group memberships and use that as my source and compare to FME Flow to work out which CRUD type of operations I need to do for the users and their roles to maintain it in the security section of Flow.
Thanks again
zoe.forbes
  • Feb 3, 2026 11:53 PM UTC
Hi ​@anryan, I thought this would be a one-off operation but I see that isn’t the case. Since there’s a “user created” system event, you could use the following as triggers:
  • A System Event Trigger in automations.
  • A Schedule as you suggested. Instead of polling all users/roles, you could retrieve System Events with an API call and use the query parameters start=[timestamp] and type=SYSTEMEVENT_USER_CREATE as a filter.
anryan
  • Feb 4, 2026 1:16 AM UTC
​@zoe.forbes Awesome. Thanks. Didn’t think of sys events with an automation
anryan
  • Feb 25, 2026 11:18 PM UTC
​@zoe.forbes I thought of something to ask relating to this.
Since you mentioned using an automation to detect a user logging in, my question is how are the privileges used (on the fly vs persistent) in FME Flow for that user?
If I use the automation approach to update/maintain the user’s privileges when the user logs in, will the user get any privileges assigned to them as part of this process?
Thanks
zoe.forbes
  • Feb 26, 2026 12:01 AM UTC
Hi ​@anryan,
User permissions in FME Flow are granted immediately once set, and persist indefinitely until revoked This means permissions will be granted as soon as the automation is complete.
When logging in for the first time however, users will likely authenticate and load the UI before this has happened. This means they’ll need to refresh the page once the automation’s ran to see items they have access to.
If you feel it’s necessary, you could use a Broadcast Message to make sure users are aware of this. I double checked in 2025.2 and can confirm new users will see a Broadcast Message which was sent out before they were created.
Please let me know if you have any questions about this or anything else!
