ARCGISONLINE MetadataOverwritter not working
  • February 18, 2025
  • 21 views
babar_ali99
Its not working with the latest FME flow. Metadata in agol is nt updated.It use to work previously.The meta data is is being read from the arcsde reader from oracle database.
emmaatsafe
  • February 19, 2025
Hi ​@babar_ali99,
To better understand the issue, could you provide a bit more detail?
  • Are you seeing any errors or warnings in the logs?
  • Is the metadata not updating at all, or is only part of it missing?
  • Have there been any changes to your ArcSDE/Oracle database setup?
  • Does it work in FME Form? Which version of FME Flow was it working on previously?
Emma
babar_ali99
  • February 20, 2025
Thanks for getting back Emma
Meta data is not updating at all.
No errors
we have upgraded oracle from 12c o 19c But I have tried updating using 12C but still its not updating
last version it worked on was FME 2022
emmaatsafe
  • February 20, 2025
Hi ​@babar_ali99
If you're comfortable sharing, could you provide the following?
  • A small sample of your source data
  • A description of your expected output
  • Your FME workspace (plus any supporting files needed to run it)
  • Your FME translation log file
  • Any other details that might help us assist you
If you’d prefer not to share here, you can also submit a support ticket and our team will be happy to take a look!
Emma
