How to Find Unicode Characters in Text String
  • August 16, 2024
  • 412 views
juliarozema
Forum|alt.badge.img+7
We have some text fields that shouldn’t have any UNICODE characters.  Turns out at least one has snuck into the data.  Is there a way to Test to find UNICODE characters and then remove them?
FME 2022.2.3
Best answer by bwn
Since FME uses a PERL implementation of RegEx, then could use StringSearcher with RegEx to find where there is a string that has a match to a non-ASCII character, and the character positions.
RegEx Pattern looking for is [^[:ascii:]]
Gives
david_r
  • August 19, 2024
You could try the AttributeEncoder with “Replace invalid characters”=Yes to transform the string to e.g. Latin-1 (or whatever you require), then compare the string before and after so see if any extended Unicode characters where replaced/removed.
bwn
Forum|alt.badge.img+26
  • August 20, 2024
Gives
juliarozema
  • August 22, 2024
Thank you @bwn this helps us see the special characters that have snuck into our data.
@david_ Thank you for also taking the time to submit an idea.  Your idea works in conjunction with @bwn.
First use the StringSearcher to find a Match for the UNICODE characters.
Then use the Attribute Encoder to remove them.
Then use the StringSearcher (during development) to confirm the UNICODE characters are gone.
Thank you both :)
