There is a way to upload/create multiple database connections to FME Server/Flow at once?
australgis
The title is self explanatory. I need to upload or create dozens of database connections and I found cumbersome to upload only once of them at a time.
How can I do that? May I share a folder with them?
Forum|alt.badge.img+55
  • July 31, 2024
Its not documented in the REST API but there is the /fmerest/v3/namedconnections/connections/ endpoint.
Its pretty straight forward to figure out from using dev tools to capture your request in the UI then using that to programatically formulate requests to FME, for example:
{"type":"Actian Ingres","parameters":[{"name":"HOST","value":"1"},{"name":"PORT","value":"II7"},{"name":"DATASET","value":"1"},{"name":"USER_NAME","value":"1"},{"name":"PASSWORD","value":"1"},{"name":"SPECIFY_JDBC_CONN_GROUP","value":"NO"},{"name":"CONNECTION_STRING","value":"<Unused>"},{"name":"MASK_CONNECTION_STRING","value":"<Unused>"},{"name":"CONNECTION_PROPERTIES","value":"<Unused>"}],"name":"test","category":"DATABASE"}
s.jager
Forum|alt.badge.img+16
  • July 31, 2024
Or create a simple workspace, with a single reader for every connection (I think I would only attach an Inspector to every reader, just to mae sure it works first), and upload that workspace. Then when uploading, make sure you check all the connections. Luckily that’s easy, just toggle the box before ‘Connections’.
virtualcitymatt
Forum|alt.badge.img+38
This is actually a nice way to be able to test your connections too. A workspace which contains important connections can be run on a schedule. If a connection gets out of date you know about it and can do something about it.
s.jager
  • July 31, 2024
@virtualcitymatt Oh! Never even thought of that, but yes, that would be a very good use indeed! Could include Web Connections as well, and other services that are called by HTTPCallers for example. That’s a brilliant idea (why didn’t I think of that? 😉😄)
