FME Form 2023.2 doesn't recognise ArcGIS Pro 3.3
cory
Forum|alt.badge.img+7
I’ve seen that FME 2023.2 Build 23764) doesn’t recognise ArcGIS Pro 3.3 for access to Esri licenses.
Will this be resolved in 2024.1? I haven’t tested 2024.0 as I’m waiting on the .1 release
Best answer by rudy_v
Hi @cory
So far as I know FME 2023.2 only supports up to ArcGIS Pro 3.2
3.3 was only released this week (07/05/2024) - so I assume it will be ok in 2024.1+ or maybe a later release of 2024.0
Notes on FME and Esri Versions and Compatibility
Esri Product Version (Python)  Recommended FME Version Comment
ArcGIS Pro 3.2.x
(3.9.18)
FME 2023.2+
Rudy
rudy_v
  • May 10, 2024
Hi @cory
ArcGIS Pro 3.2.x
(3.9.18)
FME 2023.2+
Rudy
rudy_v
  • May 14, 2024
Hi @cory
Safe - just updated - it will work from 2024.0.3 onwards
ArcGIS Pro 3.3.x
(3.11)
FME 2024.0.3 FME 2024.0.2 is provisionally compatible, however FME 2024.0.3 is the recommended FME Version to use.
