DatabaseJoiner looses curly brackets in joined attribute
reservoirdog
Forum|alt.badge.img+10
I am using FME(R) 2022.1.3.0 (20220928 - Build 22630)
I noticed while working with ArcGIS Data (FileGeodatabase), that when I use
the “DatabaseJoiner” Transformer to join attributes with curly brackets inside its values, the curly brackets are gone after joining.
e.g. Original Attribute value: {12C300A2-64C3-4494-A1E2-430CC5C5C7A9}
joined value by DatabaseJoiner: 12C300A2-64C3-4494-A1E2-430CC5C5C7A9
It this a known behaviour? Why would it get rid of the curly brackets?
Anything to do against it?
Best answer by hkingsbury
I just tried in 2023.1 and its retaining the curly brackets. Two things I can think of
  1. It was a bug that has been fixed
  2. I put the GUID in a text field, the behavior might be different if it is a GlobalID/GUID type?
To rectify it, you can use the StringConcatenator to add the opening and closing squiggly brackets
Forum|alt.badge.img+55
  • February 22, 2024
reservoirdog
  • February 23, 2024
Thanks for your reply.
Yes, I fixed it using the StringConcatenator, but I found it a weird behaviour.
Yes, the source attribute is a GlobalID datatype, maybe it behaves differently.
At the moment I cannot try a newer version of FME, because newer versions removed
the “old” SQLIte (Spatial) writer completely and I am still quite depending on that.
Thanks again for testing this out,
