FME 2023.0 - Feature Highlights
  • Mar 1, 2024 9:00 PM UTC
  • 0 replies
  • 600 views
LizAtSafe
Forum|alt.badge.img+26
Originally posted May 26th, 2023.
What’s New in FME 2023.0
The modern data environment requires new levels of flexibility. It’s time to give new life to your data. See how the latest release of FME will further enhance your productivity and fuel even more innovation for your organization.
Boost Your IT Efficiency
Every IT leader strives for efficiency. Automate IT workflows with scale, flexibility, and security, so your team is better positioned to support enterprise modernization.
Standardized Configuration
Simplify workflow deployment across multiple FME Flow environments with Deployment Parameters. Maintain and standardize FME Platform configurations, making it easy to transfer FME solutions across your development pipeline  (i.e., development, test, production).
Distributed Processing
Deploy secure, hybrid, and multi-cloud data integration workflows with the Remote Engine Service. Process data where it resides for increased security and efficiency.
Robust API Services
Automate with increased control, flexibility, and security with the improved Webhook. Orchestrate more complex and powerful automations with built-in authentication support and visibility into API request information.
Faster Deployment
Automate the deployment of FME workflows with the Command Line Interface (CLI) to deliver fast and reliable data integration pipelines.
Make Team Collaboration a Breeze
Project management and teamwork are hard when you have siloed information and a cumbersome process. Keep your team in sync to expedite project delivery.
Workspace Collaboration
Deploy robust and reliable workspaces collaboratively with the ability to compare workspaces and reconcile changes visually.
Gain Unrivaled Productivity
Enterprise data keeps getting bigger. So does the demand for faster processing and increased productivity. With the fastest-performing FME ever, you are able to do more with your data in less time.
Improved Data Visualization
Supercharge your data wrangling with faster data inspection and preview.  Process feature-rich data efficiently with optimized performance for 2D rendering.
Expand Your Data Connectivity
Unleash the power of your data wherever it resides with the largest ecosystem FME delivers. New connections are constantly being added to meet evolving market and customer needs.
Databricks Reader & Writer - Derive new insights by bringing spatial data into your datastore. Access, retrieve, and write data from and to Databricks natively within FME.
Trimble Connect Connector - Easily manage data and documents in Trimble Connect to streamline construction project collaboration.
Autodesk Revit Writer - Keep your project team informed with update-to-date As-Builts. Integrate GIS data into Revit and create a Slim BIM model to share with your team.
Generative AI Connectors - Revolutionize your data integration workflows with the latest generative AI technology.
Explore more connections using the Airtable reader & writer, ArcGIS Server Feature Service writer , Microsoft Azure Synapse SQL Reader & Writer, Precisely MRR writer, ND JSON & GeoJSON reader & writer.
Check out everything else new in FME 2023.0, including Data Types in AttributeManager, and support for conditional parameters across the platform to empower self-service data apps.
Watch this on-demand webinar to take a deep dive into all the key new features in FME 2023.0.
