WFS Data Interoperability in ArcMap
  • Mar 12, 2015 11:16 AM UTC
  • 32 views
Comparing the same output data in FME and ArcMap, with the same WFS Parameters Properties set up on both connections, same applic. schema, I am getting different results for some attributes. I.e in ArcMap I don't get values of some attributes but rather NULL. Likely not reading these values and not recognizing gml structure correctly.
Best answer by z77
No one? Perhaps someone from Safe here?
  • Mar 16, 2015 11:27 AM UTC
