Verifying credentials in the Salesforce Writer
Forum|alt.badge.img+39
Our salesforce writer credentials need to be updated as a workspace is moved between environments, there doesn't seem to be any easy way of verifying that the values copied and pasted are correct without running the workspace
Any suggestions?
virtualcitymatt
Forum|alt.badge.img+38
well *cough* you could temporally create a user parameter out of the password field.
Are you more wondering if there is a way to validate or verify? because that would be pretty handy. Seems like there should be a web connection here anyway. Weird.
  • August 1, 2023
Yes, we can parameterise and fetch the parameters into plain text but something that didn't involve actually editing the workspace would be nice. There's a password and a security token which are both password type fields
The salesforce connector uses a web connection but the reader and writer don't unfortunately.
