URGENT: Connecting GoogleDrive
dor1411993
Forum|alt.badge.img+5
Hi everyone!
I have a really strange problem connecting Google Drive to FME.
Until this morning, I could very easily connect my Google Drive to FME Desktop and then straight to the server.
As of this morning, I receive a message like this when I want to log in to Google:
ps7.jpgCan anyone help me?
Edit:
We tried to do it on another computer,
And it is the same problem.
Best answer by virtualcitymatt
virtualcitymatt wrote:
Hmm, You should go into your Google account and review your Security activity. Security>Review security activity. If you think you've been hacked or compromised then follow the support from google here: https://support.google.com/accounts/answer/6294825?hl=en
In the security settings you can review which third Party apps have access to your account. You can remove any or all including FME.
Good Luck
I'll be honest though - I've made an assumption that the response you're getting there is from a language your not familiar with and the URGENT in the question title. If I've made a false assumption then maybe it's something else.
I just set up a new connection for Google Drive with FME 2022.2.5 and had no trouble. Which version of FME Are you using?
virtualcitymatt
Forum|alt.badge.img+38
Good Luck
virtualcitymatt
Good Luck
dor1411993
  • May 11, 2023
Thank you!
It was really a problem of versions.
We use the first version of 2022, because of the compatibility with the server version.
I upgraded the FME to 2023, created the link to Google Drive there, and pulled it to the old version.. :)
