Unable to run Python Script for metadata functions of arcpy
  • Jun 1, 2016 4:35 PM UTC
  • 72 views
I am getting the error when running the metadata function of arcpy function:
arcpy.MetadataImporter_conversion (MetadataFile, TargetGenESISData)
FME API version of module 'PythonFactory' matches current internal version (3.8 20151127)
The user-specified Python interpreter `C:\\Windows\\System32\\python27.dll' is version 2.7
Python version 2.7 loaded successfully
Emptying factory pipeline
Unhandled Exception:
System.IO.FileNotFoundException: Could not load file or assembly 'GpMetadataFunctions, Version=10.1.0.0, Culture=neutral, PublicKeyToken=8fc3cc631e44ad86' or one of its dependencies. The system cannot find the file specified.
File name: 'GpMetadataFunctions, Version=10.1.0.0, Culture=neutral, PublicKeyToken=8fc3cc631e44ad86'
at System.Reflection.Assembly._nLoad(AssemblyName fileName, String codeBase, Evidence assemblySecurity, Assembly locationHint, StackCrawlMark& stackMark, Boolean throwOnFileNotFound, Boolean forIntrospection)
at System.Reflection.Assembly.InternalLoad(AssemblyName assemblyRef, Evidence assemblySecurity, StackCrawlMark& stackMark, Boolean forIntrospection)
at System.Reflection.Assembly.InternalLoad(String assemblyString, Evidence assemblySecurity, StackCrawlMark& stackMark, Boolean forIntrospection)
at System.Reflection.Assembly.Load(String assemblyString)
at GetManagedType(Char* _assembly, Char* _path, Char* _className)
Please let me know what to do
  • Jun 2, 2016 8:44 AM UTC
Hi
That looks like an ArcGIS error message.
This was my first hit using Google: https://geonet.esri.com/thread/61030
Could you try the solution listed there and tell us if it resolves the problem?
David
  • May 24, 2017 8:07 PM UTC
Hello Everyone,
The above solution posted by david_r and specified in GeoNet definitely works and you would need to do the GAC adding after each upgrade of ArcGIS from 10.x and higher.
Getting gacutil.exe required another google search. For Windows 7,go to link Code Project Link and run cmd.exe in command line with administrative privileges and run command as "GACutilLocation\\gacutil.exe" /i "C:\\Program Files (x86)\\ArcGIS\\Desktop10.0\\Bin\\GpMetadataFunctions.dll"
I hope the above helps.
  • May 25, 2017 1:20 AM UTC
Hello Everyone,
Great to hear that you found a solution and thanks for sharing it here.
