Unable to load a library in the folder: C:\\Program Files\\ArcGIS\\Pro\\bin The error number returned from GetLastError is: 127
  • Feb 28, 2023 1:08 PM UTC
  • 490 views
siza
Participant
We sporadically get this error from the SDE-DB reader. We are using FME Desktop 2022, ArcGIS Pro 2.9.5, ArcGIS for Desktop 1.8.2 + Background Geoprocessing for 1.8.2.
Log says the following:
Could not open the Enterprise Geodatabase. The error number from ArcObjects is: '-2147220952'. The error message from ArcObjects is: {The Product License has not been initialized.}
Please ensure the connection parameters are correct ([...])
It could have failed to open because it contains ArcGIS Pro-only features, for example Arcade expressions. If this is the case, please install ArcGIS Pro or Pro-compatible ArcGIS Server and 64-bit FME
GEODATABASE_SDE reader: A fatal error has occurred. Check the logfile above for details
Failed to obtain any schemas from reader 'GEODATABASE_SDE' from 1 datasets. This may be due to invalid datasets or format accessibility issues due to licensing, dependencies, or module loading. See logfile for more information
  • We tried setting the license compatibility option
  • We use the correct ArcGIS Pro/ArcGIS Desktop license
  • There is currently always at least 1 floating license not in use, so no available license should not be the issue
  • we removed old versions of background geoprocessing
Anyone have any suggestions why this error occurs?
rahulsharma
Forum|alt.badge.img+12
Hi @siza​
There is a known issue around this error, as mentioned in this article.
The error message that you shared is generally due to mismatched background geoprocessing.
Are you sure that your 64-bit background geoprocessing is for version 10.8.2?
Can you set the Esri Compatability to Esri ArcGIS Pro? Documentation link here
Can you share the entire log from the Log Window?
