Trimble Connect Authentication Error
  • October 14, 2020
  • 249 views
warrendev
Forum|alt.badge.img+28
I'm attempting to use the Trimble Connect web connection, but I am receiving an authentication error. I have a Trimble Connect account and have received my consumer key and consumer secret for authentication, but I'm not able to get it to work.
2020-10-13_18-58-50
I've reviewed the Trimble Connect API documentation, but I am still relatively new to working with API's, and this API requires multiple steps, so I'm having trouble. Does anybody have examples of authenticating with Trimble Connect with FME? I could sure use some assistance.
I downloaded the provided collection and environment in PostMan and was able to connect, but no luck getting this to work in FME.
Trimble Connect API Documentation
Best answer by warrendev
I wanted to circle back and answer this question I posted awhile back with the solution I found.
Trimble Connect now only allows the Oauth 2.0 Authorization code grant for security concerns.
Trimble Documentation Link
Create a new Oauth2.0 web connection in FME.
Enter Client Id, Client Secret and Redirect Uri that was used during sign up of the Trimble Identity.
Authorization Parameters
URL: https://identity.trimble.com/authorize?scope=openid&response_type=code
Retrieve Token Parameters
URL: https://identity.trimble.com/token?tenantDomain=trimble.com
Refresh Token Parameters
Request Format: client_id=[CLIENT_ID]&client_secret=[CLIENT_SECRET]&refresh_token=[REFRESH_TOKEN]&response_type=refresh_token&grant_type=refresh_token&tenantDomain=trimble.com
Test the connection and login with your credentials.
warrendev
  • February 1, 2021
