Technology One Connector
  • May 7, 2024 5:05 AM UTC
  • 375 views
nbombardier
Is anyone aware of a connector for FME that enables our GIS databases (Microsoft SQL) connect to a Techncology One Property & Rating database?
Best answer by saraatsafe
Hi @nbombardier, there doesn’t seem to be a connector specifically for Technology One Property & Rating, but you should be able to create your own connector either using APIs or JDBC/ODBC. I’d suggest trying ODBC (documentation here) first since you’re working with SQL databases. I hope this helps!
saraatsafe
Forum|alt.badge.img+13
  • May 8, 2024 8:48 PM UTC
nbombardier
  • May 13, 2024 11:20 PM UTC
@saraatsafe thanks,  our IT team is highly security conscious and isn't allowing sftp and I believe obdc connections off network. I'll investigate the API possibilities.
