Support fine-grained scope Git Version control
  • Nov 28, 2025 2:42 PM UTC
  • 146 views
jkr_wrk
Forum|alt.badge.img+37
I would like to look into using the integrated version control of FME Flow:
https://docs.safe.com/fme/html/FME-Flow/WebUI/Manage-Workspaces.htm#Working
So I asked for a repository within our git environment with rights so FME could access and write the workflows like mentioned here:
https://docs.safe.com/fme/html/FME-Flow/WebUI/Version-Control.htm
But our current policy disallows integrations with a wide scope and would like to use the fine-grained scope settings within github probably like mentioned here:
https://github.blog/security/application-security/introducing-fine-grained-personal-access-tokens-for-github/
Does FME also support fine-grained scope and if it doesn't would this be implemented in the near future?
Β
Β
Best answer by hkingsbury
I don’t have an answer, but I think you should make an idea out of this
hkingsbury
Forum|alt.badge.img+73
  • Dec 4, 2025 6:25 PM UTC
jkr_wrk
  • Dec 5, 2025 9:33 AM UTC
Thanks for the reply:
Created the idea:
Β
Β
