Start a work space using SMS
  • Mar 22, 2019 11:07 AM UTC
  • 53 views
boubcher
Forum|alt.badge.img+11
Is ther a way we could trigger a workspace using SMS , The wok flow is as fellow
The work space 1 , will send an SMS to the client with question the client should replay with 1 or 2 .
How could we trigger an other work space based on this response.
danilo_fme
Forum|alt.badge.img+58
  • Mar 22, 2019 11:31 AM UTC
Hi @boubcher
I suggest you to use a integration cloud communication pattaform https://www.twilio.com/
On the past I used this API with succesfull. The documentation is easy to use.
There are some options to use the API: Text, SMS, etc.
If you want a help - write here.
Thanks,
Danilo
boubcher
  • Mar 23, 2019 11:56 AM UTC
@danilo_fme
thanks I will give it a try and let you know
Thanks again
danilo_fme
  • Mar 23, 2019 2:55 PM UTC
@danilo_fme
Thanks again
Excellent @boubcher
Thanks,
Danilo
