SSL error via JSON reader; not via http caller
  • Feb 16, 2020 4:19 PM UTC
  • 30 views
I'm trying to read data from an API endpoint using a JSON reader. Unfortunately, I'm getting a http / ssl error. However, when I'm try to read data from the same API endpoint using a HTTP caller transformer, everything works fine. So, there is nothing wrong with the endpoint.
Am I encountering an error in the JSON reader? I'm usinf FME Desktop 2019.1
  • Feb 17, 2020 8:14 AM UTC
I was unable to reproduce the issue with either FME 2018.1 or 2019.2, both versions could read the URL just fine.
Are you able to post a sample workspace here that demonstrates the issue?
