SoapAction: Where do I have to add it and how in HTTPCaller transformer
  • Feb 1, 2018 9:24 PM UTC
  • 6 replies
  • 530 views
In SOAPui, I have this SOAPAction in the xml editor: SOAPAction: "http://schema.bpost.be/services/common/address/ExternalMailingAddressProofingCS/v001/validateAddress".
I don't understand where do I have to create this action in the HTTPCaller of FME?
Best answer by david_r
The SOAPAction is a header, here's a working example for a SOAP request using the HTTPCaller:
The attribute "soap_request" contains the XML block used for the request, you can e.g. use the XMLTemplater to generate it. The attribute "soap_response" will contain the XML response, which you can decompose using e.g. the XMLFlattener.
Hi @gtihon
Have you followed the example in this article? It outlines how to take the right parts from SOAPUI into the HTTPCaller.
https://knowledge.safe.com/articles/45314/working-with-soap-services.html
  • Feb 2, 2018 7:10 AM UTC
The URL doesn't seem to be available.
  • Feb 2, 2018 7:31 AM UTC
Hi jlutherthomas
Yes indeed I already follow the example but it's not mentioned exactly where and how to introduce it in HTTPCaller
  • Feb 2, 2018 7:38 AM UTC
  • Feb 2, 2018 9:19 AM UTC
Thanks very much....it works now...In fact the "SOAPAction" to be included in column Name is case sensitive i think...
  • Feb 2, 2018 9:25 AM UTC
Case sensitivity would depend on the implementation on the SOAP server back-end, but yes, I always assume case sensitivity unless anything else is specified.
