- Sketchup Studio 3d Modelling - I want to do it even if I transform the glb file into 3d tiles and go to cesium ion, is it possible in FME?
  • October 8, 2024
  • 54 views
eulniyy
Participant
saraatsafe
Forum|alt.badge.img+9
  • October 11, 2024
Hi @eulniyy
We do have a Sketchup reader that you might be able to use to read in your models-- I believe this reader expects an .skp file though so I’m not 100% sure if it would work with a glb file, but it might be worth a shot. For your writer, you can use the Cesium 3D Tiles writer. I hope this helps point you in the right direction!
