- Sketchup Studio 3d Modelling - I want to do it even if I transform the glb file into 3d tiles and go to cesium ion, is it possible in FME?
  • Oct 8, 2024 1:01 AM UTC
  • 137 views
eulniyy
Participant
saraatsafe
Forum|alt.badge.img+13
  • Oct 11, 2024 11:16 PM UTC
Hi @eulniyy,
We do have a Sketchup reader that you might be able to use to read in your models-- I believe this reader expects an .skp file though so I’m not 100% sure if it would work with a glb file, but it might be worth a shot. For your writer, you can use the Cesium 3D Tiles writer. I hope this helps point you in the right direction!
